Glaze a door - in situ or horizontal?
Discussion in 'Other Trades Talk' started by roger06, Oct 24, 2014.
  1. roger06
    roger06 Member
    Hi
    I have to re-glaze a four pane wood door. Would I be right in thinking I'm better off taking it down and lying it flat to reduce the chance of dropping a pane while putting it in? Or is it better to do it with the door hanging vertical as normal?
    Thanks
  2. gadget man
    gadget man Screwfix Select
    I would do it when it's hanging
  3. joinerjohn1
    joinerjohn1 Screwfix Select
    Yep, glaze it whilst it's hanging. ;);)
  4. roger06
    roger06 Member
    Thanks guys
    I've have now done it and think it was indeed easier left in situ. I had visions of the glass falling out and smashing while trying to fix it but luckily that didn't happen. Reckon I made an OK job of it as well seeing as it's the first time I've ever tried it. No doubt saved myself a few quid.
    Thanks again.
  5. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Oops, famous last words.......
    Mr. HandyAndy - Really
