I need to buy a drill bit that will go through wood then into a block wall but can you buy one that you don't need to use hammer action.
If I am drilling through a batten into masonry I just use a normal masonry on hammer through both and then bang a plug in.
Yeah. You can sharpen a masonry drill on a diamond grit wheel,but it's cheaper to buy a Bosch drill bit.
