https://www.tlc-direct.co.uk/Produc...dium=email&utm_source=TLC Direct Mailing List just wondered as i have some to do although they all have spurs off (and some makes are more generous with accommodating 3 cores) cheers
Shoooorley they install exactly the same way as normal double-sockets? 35mm-deep box minimum. I'd have thought. This one shows a rear view - is that your concern, a bulky back-end?) http://www.ebay.co.uk/itm/Face-Plat...g-Power-Outlet-Charger-USB-Port-/171859445370
I think he is more worried about being able to fit 3 x 2.5mm in mate. Some sockets will only take 2 x 2.5 though the MK ones will take 3 x 4mm.
yes i was referring to the 3 x 2.5 in the one hole! actually i think mk make the usb ones now so will take a look at those too
Never had a socket I could not get 3 x 2.5 into. MK and Contactum have room for 4. Kitchen fitters know all about this ;-)
Agreed. Some are easier than others. I think the last time i was putting 3 x 2.5 in the one whole was with (i think) Crabtree ones which was a bit on the tight side.
