Need to remove Wren kitchen drawer - new style
Discussion in 'Kitchen Fitters' Talk' started by Loo Loo Moakes, Apr 14, 2017.
  1. Loo Loo Moakes
    Loo Loo Moakes New Member
    Can any one tell me how to remove a new wren kitchen drawer? Need to move the drawer but can't seem to work it out?! Checked out YouTube but could only find old style! Any videos would be much appreciated! Thanks in advance!!
  2. KIAB
    KIAB Super Member
  3. Phil the Paver
    Phil the Paver Screwfix Select
    Is this yours
  4. Loo Loo Moakes
    Afraid not Ours is newer - but thank you!!!
  5. Loo Loo Moakes
  6. Allthe6earnoidea
    Allthe6earnoidea New Member
    Take front off - push up small spring loaded metal tab at same time use screwdriver to turn the cross slot (not a screw) and put somewhere safe... this gives you good access to the grey plastic clip as seen from front with drawer front removed lever down with screwdriver shaft and it should click out... drawer is now free to slide off runners... put towel or something soft to catch drawer front in case you drop it
