i have wired lights in 2 barns and now the owner has asked if I can put a socket in for him, probably for clipping sheep etc. is it possible to take a spur from the lighting circuit? It is wired in 2.5mm and is on a 15a fuse at the consumer unit
With you stating its a 15 amp fuse it seems its a bit on the aged side. Just a thought is there any other form of protection eg: rcd if not you really could do with one
