Hi, I have a switched 13amp fused connection unit that a double socket runs of in the kitchen. The light on the connection unit keeps flickering and stays on but is slightly dimmer when it's in the off position, I've checked the connections and the appliances that are plugged into the double socket work with no problem. Any ideas Thanks
It's probably just a faulty neon indicator lamp although it shouldn't be on at all when the switch is off. Sounds like it's been wired incorrectly, ie supply is on the output side.
Hi Thanks for the reply. I thought it could be wired incorrectly but it was originally fitted 6 months ago and was ok for a while, then it started flickering and staying on so I took the unit off and reconnected and it's been ok for the last 3 months and now it's started doing it again. If it was incorrectly wired would it not of done it straight away?
