Does anyone know where I can go to have an 18mm chrome pipe for a shower riser bent twice? (S shape) I have tried to find an 18mm chrome elbow (so that I only need to bend once) but it has proven impossible so only option is to bend twice. I am located in south west London so ideally not too far. Thank you
Sorry to say , no such thing in plumbing as 18mm chrome pipe. Unless its made by a shower manufacturer.
Think you'll find there is. https://www.amazon.co.uk/s/?ie=UTF8...vptwo=&hvqmt=e&hvdev=t&ref=pd_sl_96wsziikzb_e
Thank you for contributing everyone. That is indeed the piece I need to have bent (amazon item). Will that solid brass chrome plated pipe bend in an offset shape? From what I can read online bending brass is very difficult? For what is worth the bends will not be huge as the distance with not that great, may that make things easier?
When you pull a bend on chromed brass there is a risk of the electro plate cracking, moreso on brass pipe than copper. If I was you I would find a local iron works and see if they could pull the bends. Problem you have is finding someone with an 18mm former and guide. one point to consider, as its brass would need to be done mechanically rather than hand benders as brass is not a malable metal.
I've seen chrome brass tube filled with sand,plugged & then bent on formers years ago, also brass tube filled with water which is then frozen first, then bent, using same method for making trombones,trumpets,etc.
Some makers use different methods, some pour a soft liquid metal into the tube ,which then solidify, you make your bends,no kinks or creases, then melt the metal out. Similar process below with making a French Horn.
The metal used in filling the tube for bending, is known as a 'bend alloy', which has a melting point of 70°C & you can melt it with boiling water. But,there is product called Polybend, it's replacing bend alloys, which usually contains lead & can affect your health. http://www.bendalloy.co.uk/polybend.html
Resin W8 was the name I was trying to recall. QUOTE: It has a melting point of about 70DegC which can be used to fill tubes prior to bending operations. It offers excellent dimensional and wall support during bending, can be simply removed with heating and a special advantage any residue can be removed with plain water http://www.johnnealeltd.co.uk/shopresinws8.html
