I need to replace a 2 port valve currently on a HW system, the current valve is a 28mm Sunvic SM4203, this is a motor on/motor off valve, I need a replacement motor on/motor off valve with a 22mm base, can anyone suggest a replacement that meets my requirement. Thank you.
hi any 2 port 5 wire valve will work. just alter the wiring, not difficult to do. question of using the power on to the open valve, power off not required, spring return regards peter
