I'm stuck undoing a screw head that has 3 points rather than Philips 4 points. Screw head resembles an aircraft propeller...hope the description means something to someone? I was thinking about ordering the security bit set but don't know if it will help??? Replies appreciated!
DIYLIL, Ever thought that the whole point of using tamper-proof screws is to stop people like you getting into whatever it is? If they don't want you getting into it, there's probably a good reason!
If they don't want you getting into it, there's probably a good reason! Yes, you'll be able to see how simple and easy to fix it is, and you won't go to the appointed service agent and get bent over the counter.
