I need to connect a sink and dishwasher waste pipe to my external stack. The pipe run will be just under 5m. What is the minimum diameter pipe i can use. Ideally i do not want to put in an AAV. Many thanks, Ben
I kept it simple, using 40mm, as the sink trap will 40mm, & dishwasher might use standpipe,again 40mm, it saves on using reducers to step down from 40mm to 32mm.
