Hi, Does anyone know who supplies 722mm high white slab gloss, kitchen cabinet doors? Everything I have found so far has been 715mm and is too small and won't match the other units.
This site should answer all your questions, but im sure wickes supply 722mm cabinet doors http://www.kitchendoorworkshop.co.uk/?gclid=CJGFgovN474CFZShtAodHAMAbw
Wickes or Benchmark use 730 high doors on a 735 unit. Wickes take away kitchens are different but I can not remember exactly what they measure. Possibly 722 on a 725 unit.
You can get them made to order to whatever size you want. Loads of companies around: I use Apex, Crystal or Deralam. Costs are pretty close to the main distributors for standard sizes though lead-time is longer (obvious because they have to make it not just pick it from stock). You can also specify edge profile so you have a better chance of matching the existing doors.
Just fitted a Wickes 'take away' kitchen. The doors are indeed 722 high. They come in the box with the complete unit though. I do not know if you can buy them separately.
Hi Natto, Did you ever resolve this problem? I have exactly the same issue and need to replace three 722mm high white gloss slab doors. Searched everywhere and can't find them in this size!
