Adjust glazed door
Discussion in 'Kitchen Fitters' Talk' started by Andrew Williams, Mar 21, 2017.
  1. Andrew Williams
    Andrew Williams New Member
    Hi there,
    I've a glazed door that's shifted ever so slightly... well, an half inch, so it's draghty. I get the principle of moving the hinges left or right to square the door but I just can't find where to adjust on this door. I've tried an Allen key in most every nook I can, no joy...
    I've attached a pic of the hinges. Id put more up but file size ... Any advice is greatly appreciated.
  2. sospan
    sospan Screwfix Select
    No picture - yet ;)
  3. Andrew Williams
    I'll try again...
  4. Andrew Williams
  5. sospan
    The hinge in the first pic, looks like it has been moved and someone has but wall plugs in the old holes
  6. Andrew Williams
    I'll have a closer look today at that - are you referring to the two holes top and bottom? Indoor think so but that would explain why allen keys don't work. I assume that the would otherwise be the adjusting screws?
    Thanks for the quick reply by the way
  7. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    For heaven's sake. So where has it moved? Likely the glass needs packing, not the hinges.
  8. chippie244
    chippie244 Super Member
    Have you turned to religion Handy?
  9. Andrew Williams
    The doors glass has been heeled and toed (as I understand the term) so should be ok...ill look again though. Still, it would be good to know just where the adjustment screws are. It's an old door, my new doors have been pretty obvious re adjustment screws.
    Any ideas?
