Hi. I need to change the mixer tap in the kitchen as its starting to split down the side of the spout. On looking at the pipe work underneath, the pipe from the underside of the tap goes down to a soldered joint as you can see on the attached pictures. My question is, how do I change to tap, and do I need to solder pipes in?
The mixer will come will identical tails, or you could use some Flexi tails, which one ends screw into base of tap, other end connect to pipe work by compression fitting or soldered. http://www.screwfix.com/p/flexible-tap-tails-10-x-15-x-300mm-pack-of-2/4565g
How easy is it to fit the compression fittings or to solder? Bearing in mind in not a plumber but competent DIYer
If you haven't got the kit, or confident about doing the job, get a plumber, about a hour's work at most.
The soldered joint that is shown in the picture is part of the tap tail and would have been pre soldered like that out the box As Kiab says, new taps will come with either same copper tails or many taps now come with flexis Post a picture of where the tails join on to the supply pipe work and we can advice further As I diy'er myself, would say that compression fittings are easier to use than soldered if you've not got any experience, but the easiest of all has gotta be push fit tap tails (still certain rules need to be applied though) You want to buy a set of "mononloc tap spaners" before you even start as getting to the bolt on that horseshoe is a nightmare without them Also a good time to check - isolation valves fitted both hot and cold ?
Also as its a mono block tap you should have isolation and check valves as set out in water regulations 1999 You can sell water fittings that don't meet our regulations but fitting them is iligal and so is fitting an approved water fitting without the required valves
most taps are supplied with the flexis, but the connector on the end is sometimes just a female thread. They will be with M10 or M10 threads.
Hi thanks for all the replies here is a pick of where the tails meet the pipes! The only thing that resembles stops are also pictured
Thanks for the reply, the house was built in 2010 so I'm guessing it will meet the regs. The valves are shown in a pic attached to another post
