Advice on rendering
Discussion in 'Builders' Talk' started by portisheadman, Feb 27, 2017.
  1. portisheadman
    portisheadman New Member
    Hi all.
    I am looking for advice as I would like to render the front of my bungalow and then paint it.
    Generally, I am able to plaster internal walls to a half decent standard but I wouldn't attempt a ceiling.
    My bungalow is made of standard brick and its mostly small sections between the doors,windows,porch etc. Nothing big that I could have trouble smoothing out.
    What is generally used to render and to what ratios? Is it just sand / cement? What is used as the pva type?
    Just thought I'd have ago as I have always wanted to try and there are plenty of areas I could have a trial go first.
    Thanks all for any advice.
  2. koolpc
    koolpc Super Member
    Plus, dont they put waterproofer in with the mix?
  3. portisheadman
    I expect so. Not sure if you just add waterproofer or do you paint anything on the wall first as well?
