Advice please regarding splitting stair string
Discussion in 'Carpenters' Talk' started by Robotron, May 1, 2016.
  1. CGN
    CGN Screwfix Select
    It cups, it splits, it splinters, it....er does other stuff :rolleyes:
  2. chippie244
    chippie244 Super Member
    Handy isn't used to getting wood,
    CGN likes this.
  3. CGN
    CGN Screwfix Select
    If you see wood, jump on it!
  4. CGN
    CGN Screwfix Select
    As one director said....can't remember the genre :rolleyes::D
  5. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Fools, I'm saying it will turn NASTY when the heating goes on.
    Nasty, ugly, unacceptable!
    Mr. HandyAndy - Really
  6. CGN
    CGN Screwfix Select
    There's always caulk...don't leave home without it!
  7. joinerjohn1
    joinerjohn1 Screwfix Select
    Yep, should have gone with a custom made stainless steel staircase instead. :p:p:p:p
    CGN likes this.
  8. Jitender
    Jitender Screwfix Select
    Just out of interest what wood is it. I.e redwood.
    also what are risers and stringers?
    Maybe order ing one soon.
  9. dwlondon
    dwlondon Active Member
  10. KIAB
    KIAB Super Member
    Agree.
    If it was me, I would be changing it.
  11. Astramax
    Astramax Super Member
    Me thinks someone is worrying far to much!:rolleyes:
    Fill with 2 part filler or Gorilla Glue.....job done ;)
  12. Robotron
    Robotron New Member
    Nice theory, John, except I paid in full as soon as the job was completed. ;);)
    So, fellas in the trade, am I right in thinking it's normal to install a pre-split staircase for a customer and have them just accept that 'wood does that' and cross their fingers that it doesn't get worse when you actually get around to using it? :cool:
  13. Ryluer
    Ryluer Well-Known Member
    Looks like it was flat sawn through the heart wood.
    Had it been a plank laying on the floor it would have tried to "cup" slightly. And no crack would have appeared. Because its held with treads and risers then stresses occur.
    Astramaxes solution above is a good one. My advice is use it.
  14. Robo, I don't think for a second it's a 'structural' issue. Ie - it hasn't been caused by the staircase movement or stresses or lack of support or incorrect installation; it is an inherent feature of a long, thick timber plank. That it appears to be in roughly the same place as the old stair's crack is coincidental.
    Will it get worse? Quite possibly - depends on what stabilising the timber still has to do. But I doubt it'll be significantly worse.
    Will it cause loose or creaking stairs? I doubt it - tho' it might possibly cause that nearest tread to creak a wee bit.
    Can these issues be sorted without replacement? Almost certainly yes. Something like a plywood patch on the back, glued and screwed. If a tread creaks, glue the damned thing too...
    Is it an issue worthy of staircase replacement? I personally think you'd really struggle to win a case on that issue - I cannot see any impartial adjudicator agreeing with you.
    Obviously it's a concern for you, and it must be disheartening with all that lovely new work. But I personally think it's fully sortable without replacement.
    Armed with all the info from this thread, and any other research you've done yourself, time to sit down over a cuppa with the chippie. Listen to what he has to say, see if you are convinced by his reassurances of 'making it good' and guarantees about it not getting worse in future.
    And then broach 'compensation' of some sort. I dunno - if he's done other work for you of which the staircase is only a part, then perhaps he can look to give you the stairs at near cost-price or summat (ie - he doesn't actually lose out, but also doesn't make anything on it?)
    But, listen to what he has to say, and be fair-minded. You can always add your concerns about this crack on to the invoice and get him to sign it - y'know "Appearance of crack brought to builder's attention, with assurance of continued repair should it increase in size and full replacement should it become a structural issue..." summat like that?
  15. Robotron
    Robotron New Member
    Thanks for a reasoned, well-thought out reply, Devil's Advocate - that's all I am after here, a second opinion from people in the trade who know what they're talking about, and if I'm perfectly honest, perhaps a little reassurance this this isn't all going to go t*ts up in a few months and I end up ripping the lot out again to fix it.
    Getting into a dispute with the chippie (or getting 'compensation' / money off the job for that matter) is the last thing on my mind - I've already asked him to quote for 2 other jobs.
    He's on his way around now (yep, on a Bank Holiday Monday) to have a look and that should tell you all you need to know about the type of person I'm dealing with. I'm fairly convinced the staircase has come from the supplier with the split/shake in it, and nobody (including me) has noticed it until after installation.
  16. Robotron
    Robotron New Member
    Chippie's been round and reassured me that it's nothing.
    Thanks to everyone who took the time to reply.
  17. Astramax
    Refer to post number 31.;)
  18. Ryluer
  19. Fab. Looks like you have a sound guy working for you.
    No-one - not even Astra :p - can blame you, a layman, for being concerned, especially as your old staircase had a large crack in it too :).
    Happy New Renovations.
