Hi All, I live in Northern Ireland and recently I had two aerials fitted. One for BBC (Freeview) the other (RTE) Soarview - Masthead Diplexer. If I feed this cable directly to the Television - Via a Triplexed Faceplate everything works fine. I then decided to get an FM Aerial so I bought a Vision Triplexer that combines UHF and VHFIII and FM. Again if I connect this cable to the TV it works fine. So I decided to connect it to other rooms and I found that If I use a multiswitch the signal goes from around 83% to 33%. I then thought the multiswitch is at fault so I went and bought bought a Tristar 6way splitter : http://www.diy.com/departments/tristar6-way-satellite-f-splitter/571174_BQ.prd Again if I use the triplexer + triplexer faceplate it does not work. However if I use the splitter directly it works fine. So I went and bought a splitter+Combiner http://www.screwfix.com/p/labgear-psc120-s-2-way-combiner-splitter-vhf-uhf/49019 And lo and behold the triplex signal works except since it only has two outputs only a maximum of two televisions work. Can you advise where I am going wrong - My multiswtch appears to be supplying a current to the Aerial when there is actually no masthead amp? So why is it not shorting? Shall I guess the power from the multiswtich is causing excess noise on the signal? OR should I the signal from the roof be boosted with a masthead amp?
Jeeez, man, I dunno... But, if you are getting a good clean signal from your existing setup, then all you should need to do is boost it with an indoor aerial amp with multiple outputs. Problems arise when you have a poor 'dirty' signal to start with - boosters then just boost it all, so it doesn't work very well. In this situation you may need a mast-head amp instead, or a larger aerial. But, if you have an 83% signal already, I'm assuming that's quite good (and clean) so a decent indoor amp should surely be fine? (Can't be arsed working through the rest of your post - soz. I certainly didn't understand the FM aerial being connected to your TV...)
