Hi Both front and back left hand side of hob wont work, both rings on right hand side is fine. Now out of warranty but can it be fixed ? Any thoughts on this ? Thanks Sharon
No reason why it can't be fixed Sharon, did both elements stop working at the same time? If so it's probably not the elements themselves.
Every time something like this has happened to me it's been cheaper or the same to replace than repair.
Most hobs have a link in connector box for different electrical supply's it might be a loose connection there it's worth a look it's usually a U shape metal piece Don't forget to isolate supply before you try this
