Hi Customer has a roof dome which has close-able vents around the base. They are the standard 76 x 8 x 229mm vents however they have a large "eye" on them to open them with a window pole, has anyone seen any for sale anywhere ?
Mighton sell the brass pull and pole. https://www.mightonproducts.com/products/sash-window-hardware/sash-lifts-ring-pulls-and-handles/pole
needs some more description. possibly a piccie. but it sounds like a standard 9x3 metal hit and miss vent. which probably had the eye fitted onto it. which would mean cutting out some of the metal in the body plate to allow the nut/bolt to slide over.
NO. They are proper vents, not some bodge up jobbie, seen them with a eye bolt, & another sort which is hinged at one edge & can be opened various degrees, using a sash pole hook.
something like this maybe? http://www.yesterhome.com/products/...nt=683553417&gclid=CPvzttWpjM0CFdQaGwod3DQIPA
