just done a kitchen fit 5 base 1 larder 6 wall units integrated washer dishwasher fridge did all plumbing 2 masons sink hob etc fitted all panelling between worktop and wall units boxed round boiler took me 6 days charged £650
Other things to consider here yozzer (although there are more considerations) are; Took me six days - was that your initial time estimation or did you estimate higher or lower Working on day rate, estimate or quote price (fixed)
I'm with chippie on this one I look at earning around £200 per day on kitchens. Just fitted a smallish kitchen, 5 base units, 5 wall units. 1 larder unit, 2 work tops with 2 mason mitres with a sink cut out. £700 took 2.5 days, had a lad with me for half day to fit work tops as akward spaces going in and out to scribe etc.
I estimated 5 but it was a ***** very tight space walls like bananas had to cut plasterboard and insert timbers on hollow walls thermalite blocks ***** to get a fixing no first fix done on electrics and did worktops on my tod never again tho I usually enjoy kitchens but this one was a ***** and was glad to see the back of it
Depends which way you look at it. A lot of people would be quite happy to earn 650 a week! Mr. HandyAndy - Really
Did you do any electrics / gas ? Way underpriced. £250 day including sundries. Should be done in week easy so £1250. Would clear £1000 after buying bits of plumbing / electric / fixings / blades / waste.
As long as you didn't loose money. Some pounds a day is better than no pounds a day. You won't make that mistake again.
don't forget we are all working to make a living. Help people out by all means, but don't forget we need to earn a crust!
