any builders that can give me advice ? damp proof sectional garage ?
Discussion in 'Builders' Talk' started by frankieBateman, Feb 19, 2014.
  1. BuilderMCR
    BuilderMCR Active Member
  2. BuilderMCR
    You can still build on notice for extensions
  3. Sean_ork
    Sean_ork Screwfix Select
    what stage of the PP process are you at ?
    did you get the drawings done overnight ?
  4. BuilderMCR
  5. frankieBateman
    frankieBateman New Member
    To who ever asked im going to submit a full plan and go down that route. As for PP it falls under permitted devolpment yayy just received my letter back from the council i think because it doesnt have a kitchen its classed as a granny/annex, the drawings ive been working on for 3 weeks and wasnt just an over night thing ive got detailed drawings of the footing and base structure along with the cavity on the walls electrics drainage and even the roof joist's sizes and lengths of what i actually need to get. But im just having a good read around about thermolite blocks and apparently arent any good ? what would be the best cheapest option to do the inner and outer leaf out of ? i will be rendering and painting it and advice on that is appriciated. Also what plans and information do i need to submit to BC ?
    thanks
