First let me explain my equipment & setup Freesat box is a Digital Dragon with firmware up to date (as far as I can tell using the info in the link), the same as this one on flea bay for reference only http://www.ebay.co.uk/itm/271651558626 it is coupled to a MK4 Sky dish with Quad LNB, the same as Sky uses, it is the coupled to a screened wall-plate which also has a RF socket & the external TV-Aerial fitted. From the Wall-Plate the RF cable goes to the (ANT-in On) the Freesat with the RF fly lead from the (TV-Out) to the (ANT-In) on the TV, with the F-Plug fly lead from the Wall-Plate to the (LNB-In) then (HDMI-Out) to the TV's (HDMI-In) I get quite a good signal on the Satellites & DVBT For example: Using CH5 for consistancy DVBT Signal Intensity 86% Signal Quality 90% Transponder 738000KHZ/8K/64QAM PID V 1601/ A 1602/ P 1601 LCN (On) LNB Power (On) FTA Only (No) DVBS Installation LNB1 (Fixed Antenna) FTA Only (No) Network Search (No) (Greyed out) KU_ARABSAT 2/3A Satelite 1/5 Signal Intensity 87% Signal Quality 76% Transponder 10964/H/22000 PID V 2305/A 2306/ P 2305 LNB Frequency Universal(9750-10600) DiSEqC1.0 (Disable) DiSEqC1.1 (Disable) 22K Auto (greyed out) 0/12V (On) Polarity Auto NILESAT 102, 102 Satellite 2/5 Signal Intensity 87% Signal Quality 76% Transponder 10964/H/22000 PID V 2305/A 2306/ P 2305 LNB Frequency Universal(9750-10600) DiSEqC1.0 (Disable) DiSEqC1.1 (Disable) 22K Auto (greyed out) 0/12V (Off) Polarity Auto HOTBIRD 1,2,3,4 Satellite 3/5 Signal Intensity 87% Signal Quality 76% - 77% Fluctuating Transponder 10965/H/22000 PID V 2305/ A 2306/ P 2305 LNB Frequency Universal(9750-10600) DiSEqC1.0 (Disable) DiSEqC1.1 (Disable) 22K Auto (greyed out) 0/12V (Off) Polarity Auto C_ARABSAT 2/3A Satellite 4/5 Signal Intensity 87% Signal Quality 76% Transponder 3936/H/22000 PID V 2305/A 2306/ P 2305 LNB Frequency 5150 DiSEqC1.0 (Disable) DiSEqC1.1 (Disable) 22K (Off) 0/12V (Off) Polarity Auto ASTRA2 Satellite 5/5 Signal Intensity 87% Signal Quality 76% - 77% Fluctuating Transponder 10964/H/22000 PID V 2305/A 2306/ P 2305 LNB Frequency Universal(9750-10750) DiSEqC1.0 (Disable) DiSEqC1.1 (Disable) 22K Auto (greyed out) 0/12V (On) Polarity Auto The digital dragon freesat came in English, however I had to go into the Menu > Installation > DVBT Installation > DVBT Auto Scan > Country & choose United Kingdom from the default Germany, before it would find any channels. I get pretty much every channel in this list http://en.wikipedia.org/wiki/List_of_free-to-air_channels_at_28°E , with the exception of Meridain / Granada unless not listed as Meridian / Granada as (For Example there is a load of just ITV's without their regions listed Now onto the issue(s) at hand with the EPG which has been happening since day 1 of install in December 2014 On DVBT / it lists all the days programs including the previous aired daily programmes (as it should) On the Satellites the EPG only lists the Now & next, the rest of the days listing(s) are blank 1. Is this most likely to be an alignment issue 2. Is this most likely a firmware issue 3. Is this common / Known issue 4. Is this a setup issue 5. Or other issue I am leaning mostly towards (Firmware) Where would you suggest I start & what further info (if any do you require) All connections are fine & there was Petroleum Jelly AKA Vaseline, put on the external connections (to protect from the elements)
If this is a Firmware issue, Could you point me in the right direction to a known fully EPG working Freesat / FTA box as cheap as possible, preferable with 2 USB's for simultaneous recording
Way out of price range tbh , but thank you for trying Cheers FatHands I've downloaded some of their material to read later
you can get intro level for £100 then get a good server supplier everything sky has to offer and more for £50 per year no brainer
Whilst I appreciate you trying TBH I wouldn't pay out the £50 per year or any other subscription, (Bad enough paying for a TV Lisence) & since it's supposed to be FREEsat I never did have to subscribe to anything with FREEview, & since I get all the channels on a <£25 box but not a full EPG clearly does not warrant excessive money for a unit & or subscription I have asked in another forum & was informed https://www.avforums.com/threads/fta-freesat-epg-issue-s.1935860/ Here in a brand new, Freesat Approved Receiver for <£60 http://www.ebay.co.uk/itm/Manhattan...e-Receiver-Astra-28-2-7-Day-EPG-/261369344788 therefore your £100 pricing, for entry level needs to be reviewed & updated. F.Y.I It is only the EPG on the satellites that are affected as the Freeview (DVBT) Works fine
Well well well, I never expected that attitude, & expected better from member(s) on here Just because I friendly refuted your £100 price tag (with proof) for entry level as why you are Shouting @ me to "JOG ON" (your words, not mine) in my thread
