Hi all, I'm currently undertaking a project to redesign the way in which caulk and silicone sealant is packaged due to the unsustainable nature of the rigid cartridges most commonly used. If anyone could spend 5 minutes filling out the survey below it would be greatly appreciated. https://www.surveymonkey.co.uk/r/WQCXZTJ Thanks
Too late, survey already closed. Anyway best of luck with the project - very worthwhile. Not only are they wasteful in terms of materials but the contents are often unusable severla months after opening.
Whilst gone off silicone in the tube is useless for its intended use - if you cut open the tubes you find some great "rubber bullet" which are very useful to throw at idle sons and dozy workmates
