johns1999 hi my carpenter has installed my tile and battens on my hipped roof extension ready for me to tile it. i'm using valley tiles and granny bonnets. the tile battens don't seem to be in line, as i'm using granny bonnets would that be ok or cause a problem as they seem to be out by quite a bit? see photo also the new battens don't match the height of the existing roof battens. should these be the same height? see other photo he says you won't notice it once its tiled but i'm not so sure. any advice appreciated, thanks in advance
When I had my roof done, the manufacturer/designer called in and talked it through with chippy. They suggested they did that to stop any problems. The chippy was reluctant and a bit off about it? Strange that. Anyway, he said after it was a good job they came. Maybe you should do same. Have a site meeting to walk through the problems and get back on track.
The battens also need to line up if you are using valley tiles, and from the photo it does not look like they are.
No that is not the setting out for 10x6 valley tiles. That looks like a hip for some other type of tile.
thanks for the advice. if he has to rebatten it, does he need to relay it again with new felt? i'm assuming you do
Completely replaced, most likely have to be new batten as well. Had roof done here last year, roofer used ring shank nails to secure batten,would have been almost impossible to remove them, if they had to be removed.
I would also fit "valley boards". This will give something solid to fix the felt to and also support the ends of the battens. Even with valley tiles, I run an additional length of water proof material or felt along the valley boards just in case. You may also want to consider where you are going to match the old tiles and new ones, try and keep one colour to one side - even if it may mean stripping some existing tiles so they match. It will look a lot better if it is all consistent
Looking at the pictures would agree too, Used valley board. Not getting the correct overlap with underlay there. Looks like good underlay too. https://www.roofinglines.co.uk/prod...x-330mm-x-3m?gclid=CNew1diRyNQCFQe-7Qod2KsEbw
Looks like clipped nails possibly from nail gun. Galvanised ring shank is what roofer used here some years ago on roof at old house.
Most larger gauge nail guns use ringed galv nails. It will be a problem removing them as most roof battens aren't the best timber and as soon as you start prying them lose they will normally snap.
Yeah I need to have a count up to see what I've got and work out where best to put the old ones but thanks I will keep them to just one of the sides
The roofer used a paslode gun. Batten widths shouldn't be a problem. Just need to be set at the same laps as the 'plain tiles' used have nibs which hook over the edge before being nailed.
They're not ring shank as I bought them for him. They're just 63mm galv wires. But yes from a nail gun.
