Hi Guys N gals Need some advice. I have fitted a new central heating system, because my house has concrete floors i have run the supply and return pipe in the loft (plastic 22mm) and dropped plastic 15mm pipes down to the radiators. Do i need to fit a auto bleed valve at the highest point of the system and if yes do i need to fit it on both the supply and return or will one do. I have fitted a magna clean type filter which has a bleed screw on it , would this be enough to bleed the air. I am using speed fit fittings. Cheers Confused . com
