Not sure if this is electrical or plumbing. I'm plagued with condensation in a bathroom in an old tenement building. I plan to fit a ceiling mounted extractor and duct it to an exterior wall. It's main use will when shower is on. Is there a preferred position for the fan. Bathroom measures about 4m long by about 2.5m wide. Shower id by the door with a window at far end. Do i mount fan near the window, central or nearer the shower.
Use a centrifugal fan mounted in the loft. You can put a grill directly over the shower then with ducting to fan then duct to outside wall. Will be a better job with more 'suction'. Ive fitted 3 of these recently and are good value. http://www.superlecdirect.com/venti...nta-inline-2-speed-fan-timed-version-9041086/
It's a tenement building, i'm on ground floor. Ceiling is a hung ceiling with about a 1.5m space. I need to take it to the outside wall and i'm limited with access to ceiling space.
