I'm going to be replacing the silicon sealant around the bath shortly, it's black with mould. Any suggestions for a white sealant that will stay mould free for a while.
Make sure you use 'sanitary silicone sealant' rather than general purpose stuff, and look for something on the tube saying it contains a fungicide. Should last more than a few years.
Sealant around a empty bath will usually crack as soon as you fill it, so make sure you fill bath before doing the sealant & then leave it filled 24 hours until sealant as set.
QUOTE="gryphon, post: 1522661, member: 98068"]I'm going to be replacing the silicon sealant around the bath shortly, it's black with mould. Any suggestions for a white sealant that will stay mould free for a while.[/QUOTE] I always use this: Never had a problem with it, but any silicone that not cleaned every now and then will succumb to mold eventually.
Hello, Keeping bathroom grout and silicone clean is a problem many people face. The problems are always caused by moisture and lack of ventilation. On my DIY blog I wrote a handy guide for dealing with bathroom mould problems. I also recommend a grout sealant spray on there that could be used on your new anti bacterial silicone. I hope this helps, and good luck!
