Been working on a job where I was faced with changing and moving a CU. The CU was a mess! It was an old Hager split load and at some time a garage door was installed and the guide rail was installed right across it making it a PITA to get to and work on. The best part was the cover was held in place by jamming two short lengths of PVC conduit between the cover and the back of the rail!
Re-sized the photo and its uploaded now. The new board is about face height and looks a lot neater. Not quite finished yet but proud of this one.
Very Nice cable work Un, mine looks a little like the first picture and hoping it will look something like your finished job, got a BG unit being changed to a Hager unit. B J
That's those boards with loads of space for RCBOs you posted about a while ago? It makes for a neat job with RCBOs. Is it Denmans/ Steeple brand ? They seem to cover the whole of the UK apart from where I am...
Lovely work UP, nice one! Was the board going in the direction of the cables, or did you need to extend? Stateit - Denmans aren't in my area, although i believe this it their mail-order website mate: http://www.allaboutelectrics.co.uk/
Yes that's the Denmans Curve CUR-M14 14-way. The one in my logo is the 10-way version. @fats. I was able to bring most of the circuits in at the sides because they were longer. The ones I had to extend I put inside a piece of 100 x 75 trunking left over from another job.
Nice little job there mate. What's the gen with the 4 lights cables into that single 6a rcbo? Looks like one is covered in insulation tape?
This is one of my better installs. BEFORE. I added a lighting circuit. AFTER. I really wish the pubs would not open at dinner time
Lol, just plain ran out of ways mate. It was the best way to get around it. Four circuits in the one RCBO.
Insulation tape - dirty! Insulation is an installation aid, nothing more! I hate seeing taped up joints and crimps!
It is inevitable I suppose that every photo and every comment gets criticised irrespective of whether its good bad or indifferent. Insulation tape is good enough mate. What else would you use? Wagos are unnecessary its accessible, connector blocks are untidy and heat shrink sleeving is too damned faffy and awkward to do. Ok! Taped up crimps are absolutely fine. Its better than leaving them untaped.
Untapped all the time for me. Tape is a bodge. Why would you try to insulate an already insulated crimp? Insulation tape has many uses. Oddly, insulating is not really one of them. It's used to tape cables to cables or cables to pull throughs and things like that. Not for leaving in situ for years to go sticky and cacky.
Must say Lec I never use insulating tape to tape cables together - I use ties which are not pulled to tight mind.
