Got to have my drive and front garden done,with all the rain we had earlier this year the weeds have shot out through the gravel,i pulled them up once but twice as many grew back. Now the question,block paving or concrete,i have an idea of pro's and con's so lets hear yours. Area wise my drive and front garden are like an 'L' shape,the drive/parking space on the left and the front garden at 90 degrees to it,just like an 'L',about 25 sq m in total,any ideas guys? Im swaying towards concrete as i will be parking a van on it and i know after time with block paving you get two tramlines,true or not?
you don't get tram lines if its done properly ie. at least 6" of MOT. If your doing it, are you following this new regulation regarding block paving front drives as it adds a lot of cost. Plus its hard to give you an idea of cost for block paving as it depends on the type of blocks. you can get blocks from £9 per m2 to over £20 per m2. Try the AJ mcormack website. last time I looked, it gave a good idea of block paving costs
AS lb says, new regs are tough on non-pervious drive surfaces due to the lack of rainwater funding its way into natural underground storage - instead it runs off into our drains. You can get pervious concrete, but I don't know what types of finish are available. I personally wouldn't risk trying to 'get away with it', 'cos an eagle-eyed council fellow could make you rip it all up again. Blocks, in my view, are much nicer anyway, and can be laid in many different patterns and colours - have a really good look on t'web for ideas. Some near-neighbours have a large shared imprinted concrete drive which I think looks dreadful - not my cup of tea at all - but others think looks good.
'tough'!!!!!!!!! All you do is make sure the rain water doesn't shed onto the street and soaks into the ground on your property. Hardly difficult, even with impervious blocks!
'tough'!!!!!!!!! All you do is make sure the rain water doesn't shed onto the street and soaks into the ground on your property. Hardly difficult, even with impervious blocks! I have thought about that too lol! 'Oh yeah - imprint is horrid. Cheap blocks aren't much better. Try something original!' Ok like what though? ' Have you considered a resin drive as opposed to concrete or block finish?' Never heard of it,tell me more
tell a lie yes i have,saw it once on ground force i think,cement mixer+bag of aggregate+tub of resin,mix up,spread out and tamp down.Hmmmm
Sorry i thought it was a serious question and i gave a genuine alternative to your other options.And you seem to have a complete misconception of how resin drives are laid.Regards mjp
'Sorry i thought it was a serious question and i gave a genuine alternative to your other options.And you seem to have a complete misconception of how resin drives are laid.' Thanks for the genuine alternative,i took it seriously. Why do i have a complete misconception of how its laid,thats how i saw it being laid,admittedly it was a path. Im i talking about the same stuff,sorry but i was being serious
My apologies. Just put resin drives into your search engine and it will bring up various firms etc Regards mjp
Stone or good quality concrete paving, cobbles, creative mix of materials, see what's sitting at your local reclamation yard. I've even started having a fond liking for crazy paving!
My own preference is - gravel! Just finishing building low walls to contain the drive area, and will be laying green Welsh granite chippings - yummy colour, especially after rain. Mind you, it does require the application of a specialised product. What's it called again? Oh yeah - weedkiller.
i've used gallons of weed killer but they just gobbled it all up,the guy that i bought the house of bodged it,i scraped some gravel away to find he'd used roofing felt to stop the weeds coming through,like many things here
With any gravel (I quite like it too) no matter what membrane you put down, things still grow. I'm near the sea, so all the stuff that grows on the shingle just above high tide (Sea Kale, Thrift etc.) grows along with all the other colonizing weeds.
Don't you find, if using a membrane, the gravel just slides around when you drive over it? My gravel is simply laid over the substrate which keeps it nicely in place. Yep, lots of weeds, but that's because I haven't done anything to control it since the current gravel is cheap stuff which was designed to make the drive usable while lots of outside work was being done. The new gravel will haver regular coats of 'pathclear', or better still, sodium chlorate (which you must ensure can't drain through onto your flower beds...) Just spread a fresh ton over it every couple of years
Depends what membrane you use and how much coverage/at what layer you put it I suppose (put it under crushed base & no problem). I haven't bothered either. Only trouble with liberal use of weedkiller is other nearby plants you might like! A rake over in a dry spell and a few minutes pulling does for 99% of the weeds anyway.
I second the recommendation for a Resin Bonded Driveways or Resin Bound Driveways they offer great value and are durable and aesthetically pleasing.
