Blocked waste/sewerage
Discussion in 'Builders' Talk' started by shadowfax, Mar 26, 2017.
  1. shadowfax
    shadowfax Member
    Hi guys can anyone recommend a waste sewage business in Poole/Bournemouth area? I see a few online but have no experience with this sort of thing.
    I have two inspection? chambers in my garden. The one nearest the downstairs toilet is blocked to the top with the brown stuff.
    The next one about 10 yds away down the line is clear. The upstairs toilet and downstairs sink are o.k. They are between the blockage and the clear chamber.
    Any idea of costs.
    Cheers Peter
  2. KIAB
    KIAB Super Member
    P. Gee likes this.
  3. KIAB
    KIAB Super Member
  4. Joe95
    Joe95 Screwfix Select
  5. shadowfax
    shadowfax Member
  6. KIAB
    KIAB Super Member
  7. Jitender
    Jitender Screwfix Select
    Used Dyno Rod couple of weeks back. Someone blocked it with sanitary pads :D
    It will probably quire jetting. The charge is £145 to use jetting equipment, £90 if blockage can be done manually.
  8. Jitender
    You will most likely loose your appetite for a few days.....
    gadget man, KIAB and Joe95 like this.
  9. Joe95
    KIAB likes this.
