Hello All, I am putting a new bathroom in. At the moment I am taking tiles off the wall so had to take the radiator off. I am fitting a new radiator when the tiling is finished. My problem is, I went to switch the heating on today and the boiler has a flow issue, the flow temp rockets up to 90c. I don't understand why this is because the radiator I took off had a bypass between the flow and return pipes that went to the radiator so surely I still should have flow around the system?? Please help
Panic over, Sorted it now. The AAV on the boiler was blocked solid and the boiler must have been air locked.
