Broken 9 Month old Iron Gate
Discussion in 'Other Trades Talk' started by Chris101, Dec 6, 2016.
  1. KIAB
    KIAB Super Member
    Shouldn't be an issue, using right rod like E6010/13 or similar, will give good pentration.:)
    could even put a bevel on hanging eye.
  2. CGN
    CGN Screwfix Select
    It's all about choosing the best rod for me! :D
    KIAB likes this.
  3. Phil the Paver
    For that gate a 2.5mm rod will be more than enough.
    Looking at how it was done, some STIKALL would be better. :D:D:D:D:D
    KIAB likes this.
  4. Is that DA welding ? :p
    KIAB and Phil the Paver like this.
  5. Phil the Paver
    You got it.
  6. CGN
    CGN Screwfix Select
    Can you get it in black? :D
    Phil the Paver likes this.
  7. KIAB
    KIAB Super Member
    Yes.:eek:
    [​IMG]
    CGN likes this.
  8. Phil the Paver
    Yep.
    :p:p:p
    CGN likes this.
  9. Phil the Paver
    Beat me :D:D:D:D
    KIAB likes this.
  10. facilities
    facilities Guest
    Speaking as someone who has served their time to welding and spent many years welding to coded standard, arc or stick welding as it is known is the only way to go, I have used all the processes mentioned including Tig, Mig welding can be used on thicker sections but ideally it should be in a workshop so as the gas shield cannot be blown away by a slight wind, Gas welding is to some extent outdated but is still useful in some instances, this is an easy job for someone who can weld to a reasonable standard with a stick welding set either generator driven or if there is a power source that can withstand the load just use a plug in set, Phils welding set looks ideal.
    I would say for this to fail and rust in less than a year is not good, the gate and post should have been galvanised dipped after welding then painted, I would say the metal has never been galvanised, if it had been welded and treated correctly it would have lasted easily 15 + years and shown no sign of rust
  11. CGN
    CGN Screwfix Select
    It's ok, we've fixed it now with stixall...black stixall. Flatted down between applications, light coat of PVA, then 2 medium coats of zinsser 123, rubbed down with 80, then 120 grit, quick smear of SBR, flick over with a jappenese water stone then top coated with a propriatory black paint. :D
  12. Phil the Paver
    Masonry paint at that. :D
    KIAB and CGN like this.
  13. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    That's not good enough. You forgot the cable-tie.
  14. KIAB
    KIAB Super Member
    You missed 406 stablishing solution...:p
    CGN likes this.
  15. Phil the Paver
    That's your baby, how could we forget that. :p:p
    CGN and KIAB like this.
  16. CGN
    CGN Screwfix Select
    Just goes to show...there's always more to learn! Did I come close? :D
    KIAB likes this.
  17. koolpc
    koolpc Super Member
    Dynamite. Thats what i would use on that. :p
  18. Cough... children, really.
    Anyhoo - any chance of photos of the broken pillar? Surely that's more relevant to this thread?
  19. Phil the Paver
    Pillar?????
    That's a different thread.
    Deleted member 33931 likes this.
  20. Oops! :oops:
