Decided to get cracking with routing network cables from the attic down inside a lathe and plaster wall to the rooms below whilst the wife is away for a few days. All was going perfectly until this happened.... I somehow managed to fall with my hand going through the roof and punching the cornice off in the master bedroom (ignore the wallpaper...that is a future task!)! What do I do...she will be back in a few days and my nuts will be in a vice! What are my options? Fill with plaster and gradually work up in layers to try and restore some detail? Chop out a section and try and get it fabricated- but where? Emigrate? Any and all help will be greatly appreciated!
Oooooh looks nasty. That hole doesn't look too good either. Get on you tube and search decorative cornice repair. Tbh its a specialist job
Get some plaster of paris or small bag of casting plaster and sculpt it as it is just a small hole. To get it done properly you would need to cut out a section of it to get it cast.
Quite a few firms around who do repairs, they use a latex type substance to make a mould from a non damaged section to make the new piece in plaster. When they finished, you struggle to find the repair. http://www.cornicerepairslondon.co.uk/
Not sure what I'm taking about but could you not use a mould of the exsisting. Ain't got a clue how lol. **** happens
As you say, fill with plaster - use a setting type (one you mix with water) and fill t'ole right in and right up. Take it slightly proud and then use shaped formers - anything, the ends of small paint brush handles, kitchen knives, spoons, not forks..., whatevs - to get the shape roughly right. As it sets - probably after around a half-hour (perhaps less) - press it more firmly into shape; it'll be more stiff and 'plastic'. After is has fully 'set' (it doesn't have to have dried), use small scrapers/model files/whatevs to work the plaster back down to match. Once dry, use an edge of fine sandpaper to finish off any rough edges. Be prepared to add small amounts of fine-surface filler to fill in any wee dips and holes. This is perfectly doable. Once emulsioned, you won't notice...
I'm sure you could manage to get that back to original with a bit of tlc. Firstly, stuff the hole with an offcut roughly shaped of plasterboard, to fit tightly and leave plenty to fill over. PVA it in there. When dry or dry-ish, fill as said before with plaster of paris or Artex. Find it better to fill it nearly, let it dry, then top it shape it, let it dry and sand it. Mr. HandyAndy - Really
No to foam, might end up more damage, if you squirt too much in. Easifill is perfect for repairs, & a couple of small pieces thin ply,with hole drilled through them & joined together with string & which you can get through the hole.Could even use something like Stixall to help hold ply in place. Hold ply in place with string while filling,when dry snip off excess string & finish off with filler.
I wasn't going to blast the stuff in Kiab just a gentle controlled surgical squirt to stop easifill dripping through
Squiiiiiiiiirrrrrrttttt. Nope, still not filled. Squuiiirrrrrrrrrrrtttttt. Nope. Squiiiiiiiiiirrrrrrrrrtttttttt. Damn, I can't open the loft hatch.
Years ago I had similar experience, fill a hole with expanding foam, very little expansion, thought it was a dodgy can, so in went another can, still nothing, couldn't understand it, when there was banging on the front door & one very irate neighbour. Pop next door & there was my foam coming out from a larder, it was full, everything was encased with the foam,after clearing up there was board up air vent which the foam had come through.
