Friend and me are looking at a small plot with PP to fill the gap between existing terrace houses. Its quite small with a span of 4m although quite deep. I realise the Party Wall Act will take effect and I am not sure at the mo whether they have approval from both neighbours. How generally are these built and what do we need to look out for? On the party walls is this dot n dabbed or do new walls have to be built? [Either side are 9" solid.] Which way in an ideal world would the footings run, is a reinforced slab an option? Your thoughts/advice appreciated!
Walk away. Party walls agreements cost money,sometimes silly amounts, not hundreds, but thousands & sometimes hassle,a lot, can end up a money pit, wouldn't touch it myself.
I ain't in the business and I know nothing at all about it, but I wouldn't touch it with a barge-pole. Just my opinion. Mr. HandyAndy - Really
Since the plot is quite deep, is it possible to set the house back to avoid any party wall issues ? I would have a trawl around some architects to see what they think as the build costs may outweigh the value
New wall skin either side, underpinning existing founds either side. 4m tuns to 3600mm. Planners wouldn't let you set back in a terrace I'm sure. You'll not be able to raise your ridge above the neighbours ridge line. Would make sense in central London where prices are high. What price would a terrace house be valued at? Would need to be +£150k
If you can find some houses in London for a £150k, I would have a couple. Got excited on Zoopla when I thought I had found a house for sale for £75k but it was just the garage
There has to be an episode where the guy buys a house in the auction, goes outside to have a smoke, sells the house to a passer by for a £50k profit. Goes back in buys two more houses where one house the owner has left a Rembrandt on the wall before leaving and the other has a classic American car in the garage with both the Roswell and Kennedy assassination tapes in the glove box.
