Hi I have a cupboard which has about 12 of these hinges in and they're all beginning to fail I can't find reasonably priced replacements - most sources I found want £10 each - this is just an old MFI cupboard and £120 on hinges is just annoying I'm also concerned that they are not that long lasting - one of the doors has a heavy mirror and that takes its toll. So, is there any simple replacement for these hinges? Cheers Phil
Depending on the size of the cutout, looks like you could maybe change both parts for normal kitchen unit concealed hinges. Mr. HandyAndy - Really
These catches are designed for the door to be mounted on the outside of a "front panel" of the cupboard - all the hinges I see mount the cupboard side of the hinge on the side wall on the inside of the cupboard. Maybe I'm just not looking right. I'll have a good look at ironmongery direct Cheers
