Hmmmmm there might be a malleability differential between a home fabricated and a factory purpose made link Chips. One has to ask why might there be a malleability differential? The answer being that one of them might have alloy/s added, and the pukka one might not. It could be the other way round of course..I don't know because I am not a metallurgist.
JP, even small amounts of impurities will significantly change the conductivity of copper. To be classed as High Conductivity (HC) it needs to be 99.9% pure. The 0.1% covers other impurities and oxygen. Conductivity is based as a percentage on an IACS scale. HC copper is 100%. Drop in 15% zinc, you get brass which is 28% IACS. Phosphorus is particularly bad, less than 0.05% in HC copper will drop its IACS to 80% So while copper may be copper. Not all copper is suitable for electrical use. I once visited a copper smelting plant in India, they were putting everything into the mix, old pipes, transformer windings, you name it. I doubt if they could ever get it pure enough for busbars, but they never the less produced them The bloke grabbing the red hot bar out of the extruder with a pair of tongs and running along the roller bed with it was a sight to be seen, not sure the flip flops offered much protection though!
