Hi I have recently bought a house and the pipes through the house are lead and I want to cap them off, I wanted to ask for advice on the best way of doing it I've looked on screw fix and found the below item but wasn't sure if this would work any advice would be greatly appreciated. http://www.screwfix.com/p/pegler-px...gclsrc=aw.ds&dclid=CI22ypn5mtUCFYe1UQodS3UO5Q
Will there be any other lead pipe still in use, your replacing lead with copper. No way to isolate lead pipe(s) at source, because you will creates a deadleg which is not permitted, if my memory of the water regs is correct.
Yes after the stopcock I was going to look at getting some kind of coupler to join the new copper pipe to the existing lead pipe. Thanks
Yes, lead to copper coupler. Philmac/Plasson equivalant might be cheaper. Can't you get water board to replace the lead, they use to do a free lead replacement scheme
