View attachment 19371 I want to cap this waste pipe but am unsure what fitting I need, ideally cap it at the end of the grey pipe but I don't know if it is a push fit or welded pipe fitting? View attachment 19371 Or cap where grey pipe enters soil pipe junction thingy if push fit?
110mm blanking plug. McAlpine DC4-BL, or Floplast SP296G or similar. And a linky: http://www.screwfix.com/p/floplast-sp296g-socket-plug-grey/18082?dclid=CKj2-OvoqdYCFUeI7QodYhwLLg
Thanks KIAB, where should this be fitted where the white pipe is fitted to the grey pipe or at the other end where it enters junction thingy?
Thanks again KIAB, guess I could find it cheaper but as screwfix just up the road will go with that one. I'll try and fit at the junction end but access is a bit tight and maybe awkward as I assume it will need a bit of fairy liquid or though I do have some silicone spray that might help.
Silicone spray will help, also spray rubber seal in branch,should go in fairly easily end cap. Access doesn't look too bad, had worst.
