hello, i was wondering can polystyrene board be used in the cavity of a kitchen extension? i have 2 sheets of 70 mm kooltherm which i am going to use and was wondering about polystyrene? i know the kooltherm is foiled both sides and the polystyrene is not, if i foil both sides of the poly can this be used? at least then it will have a vapour barrier on both side just like the kooltherm. if not why not? thanks in advance
polystyrene does not have the same U value as kooltherm or any other form of insulation board, so no it's not BC complaint.
