Ceiling crack
Discussion in 'Painters' Talk' started by gordy1, Aug 6, 2017.
  1. gordy1
    gordy1 Member
    Hi, I have a problem filling a hair line crack on my ceiling (plasterboard joint), I have tried different fillers over the past few years one of them being decoraters caulk but none of them last long the crack keeps reappearing, I have tried raking the joint out to get more filler in but this doesn't work, may Now have damaged the scrim under the plaster, can anyone recommend a good flexible filler that could do a lasting job??, would appreciate anyone's idea on this.
  2. fillyboy
    fillyboy Screwfix Select
    crack repair tape from Brewers, then fill over the top.
  3. DIYDave.
    DIYDave. Screwfix Select
    If the crack is reappearing, then you've got movement - either the plaster boards or the ceiling joists or both
    If you push on the PB either side of the crack, do the boards move slightly
    Do you know if the PB joint lines up on a joist or noggin. Can try knocking a thin nail through the PB either side of the crack to see if you hit timber, or if the nail just disappears right through the board
    If you have movement in the boards and if there is timber under the join, then happy days indeed
    Add PB screws either side of the crack to firm up the boards. Drive heads just below surface but not tearing the face paper (can get PB screw bits that stop screw going in too deep)
    Rack out crack, brush out loose bits. I would then brush PVA diluted 1-5 into the crack and let it soak in to edges of PB and dry, then repeat (maybe) dont get PVA all over the ceiling as may cause an issue when you paint ceiling. So, small artists brush or similiar to apply PVA, wipe ceiling either side of crack with damp cloth to remove excess
    Then fill, sand, mist coat, emulsion, should be all good
    If no timber to screw into, then PVA, scrim tape (will need to remove plaster just wider than tape from either side of crack) then filler, sand, mist coat, emulsion
    Any quality filler I guess, Toupret interior is very good, SF sell it. Any thing branded 'flexible' will only put up with so much abuse and flexing though before it fails- it won't perform miracles. Always best to sort the problem first instead of relying on secondary methods and 'snake oil' !
    If loose joists ...... dunno, much bigger problem
  4. gordy1
    gordy1 Member
    Thanks lads both very good suggestions will look at both at the weekend, thanks again.
