I have noticed that the water in the expansion tank is very hot. Looking today, I saw that the vent pipe terminates underneath the water and I suspect that it is causing its own circulation? Should i ignore it, or should I cut the vent pipe shorter so it sits above the water? Swizz
cutting the vent is like making love to a buitifull woman ...yes tony cut the pipe, this MAY stop the circulation, but at least you will see then if the pump is overpumping, if its still running turn the pump to a lower setting.
What sort of tank is it? A baby was killed not so long ago when a faulty heating system "pumped over" into a plastic expansion tank. The tank eventually softened due to the heat and it collapsed dumped a ton of boiling water on the kid.
Get your facts straight! That was the main CWS storage tank collapsing after a faulty immersion boiled over! NOT the same thing. Do as Tom says, cut or lift the vent out of the water.
Cheers guys, cut the pipe back and it seems better. Next problem though! Just fitted a new vertical rad in extension bedroom, and I noticed this morning a wheezing sound inside it. Every 30 seconds it let out a long 'sigh'. I thought it was the misses heavy breathing again and thought my luck was in, but alas, it was the rad. Any ideas? Swizz
The vent being submerged will be the problem it as created a circulation,probably the vent has slipped needs clipping.
No, it has only happened since I lifted the vent above the water! There does seem to be quite a bit of air gurgling its way around the system, so I will keep bleeding it for the next few days and then ask again if I am woken by heavy breathing and sighing again. Swizz
Tony look for an air vent in the loft and get above the vertical rad, badly plumbed these can be a nightmare to bleed. If you can't find an air vent put a bottle aav off the return up there. http://www.screwfix.com/prods/97868/Plumbing/Brassware/Bottle-Air-Vent-15mm
