Changing a combi boiler diverter valve
Discussion in 'Plumbers' Talk' started by ghekoman, Feb 26, 2012.
  1. ghekoman
    ghekoman New Member
    Hello everyone - this is my 1st post so here goes...
    I have a worcester bosch heatslave oil fired combi boiler and the diverter valve is sticking which means I have the heating coming on when it is not required or, the hot water doesn't work.
    I know it is the valve because I can take the actuator off the spigot and tap it gently with a hammer to see it rise to its rightful position.
    The fault is intermittant and i am getting a bit fed up with going outside to free the valve up.
    My question is this.... Is it possible to drain just the boiler without the entire system so that I can replace the faulty diverter cartridge?
    I can isolate the cold feed and I have found the drain off point at the bottom of the boiler. I cannot find any valves on the pipework that will allow me to isolate the boiler from the hot water and heating system.
    I had thought of using a pipe freezer to allow me to cut out small sections from the pipes and install push fit cut off valves and, in this way I could keep the water in the system isolated whilst I drained the boiler and replaced the cartridge. I suppose this would also give an advantage when it comes to working on the boiler in the future.
    I would imagine that the air in the system caused by draining the boiler could be purged through the taps and the radiators.
    I have never drained an entire system completely and, it seems like a bit of a faff compared to fitting pushfit valves.
    Any comments about this would be gratefully received.
    Thanks
  2. graceland
    graceland New Member
    If you've got a freeze kit go for it, whats the worse that can happen lol
