Hi all what is the preferred method of fitting a Dudley flush. I have heard silicone is fround upon over the years but I always see it. Tried just using the rubber and had leaks today previously I've used plumbers mate. What do you guys find it the best. Any info would be great
I use clear sanitary seal just a bit round both sides of the rubber I've never been called back in ten years or so cause of the seal had has failed Not everyone's method but never caused me a problem
Yes plumber said today that he uses silicone but other people then say if it's got a rubber washer. I have to re do it now as it's leaking. Where is the supplier for that? I was thinking ct1
The people saying they never have had a problem are they installing new on to new. If you are Installing new Dudley on to old toilet maybe that's where it's a ball ache. Must be plenty of people still using horses cause I'm constantly seeing it. Thanks for the replies tho .
Have replaced syphons with dudley ones on both ceramic and plastic cisterns without a problem. Have also fitted them in new cisterns without a problem.
I have fitted plenty of flush valves and have always use clear silicon without any problems - never had a leak. I use the supplied washer but apply silicon underneath the back nut. Btw, if you are fitting a Dudley flush, get the one that you can remove without taking the cistern off.
Alway have put a smear of Plumbers Gold sealant on the washer, & base of syphon,just in case outlet is slightly uneven.
As advised by others silicon should not be necessary, if you do decide to use a sealant I've never had anything get past this, Fernox ls-x leak sealer (23614) stocked by our hosts
Never seen the stuff,it has only been out for a couple of years from what I can gather. Never had a need for sealant for these syphons.
Well gone back to the job today and was leaking. So off the syphon came again fitted it three times altogether trying to get it to seal. Then there is a risk of over tightening. Wasn't really an issue as I could get back to it. Put a bit of sealant just By the washer on then it worked like a dream 1st time. I jumped on my horse smiling.
