I'm not a plumber, but looking for some advice... I'm chasing speedfit pipe into a solid wall for a towel radiator. I'm going to cover the pipe with duct tape and cement it in. My question is, do I also cement in the elbow joint? And do I leave pipe sticking out of the elbow joint (to attach to the rad valve) when the plasterer comes and he plasters around it, or leave it as it is in the pic? Basically, what should I do before I get the plasterer in?
Look up conduit pipe and boxing. Might help you. I looked up a few other threads for you and noticed this was mentioned by several people. Hope that helps
Thank you Miss Pickle! I can put the pipe in conduit but if the purpose is so it's replaceable/maintainable then cementing in the elbows will prevent any maintenance. Plus the whole thing will be under tiles. Surely it's got to be completely cemented in so the pipes are sticking out of cement? They'll have no wiggle-room for adjustment. Is that normal?
I dunno. I just paint Be interesting to see what the men say women eh? Errrrm kiab? Are you busy? As far as I can tell Patrick you use conduit, clip it securely, box or plasterboard and then skim over. The pipe would then only have skim round it where it enters the wall. But DO NOT do this without speaking to somebody on here who knows what they are doing first they will be along shortly I hope
102 views so far Patrick and I'm the only one that stopped by to try and help! What's the matter with them all ???
Why not plastic though rulland? If conduit, clipped securely and boxed or plasterboard? Just curious as to why you say that.
And Patrick ? What made you go with plastic over copper? Or was that something the plumber chose What was his reasons? All good stuff for other peeps viewing threads in the future
Speedfit out of sight and copper in sight seems to be the general consensus So do you put copper into the plastic pipe then so its copper on show. Keep seeing "don't fit chrome to speedfit" oooh why's that then? Its great fun this is
I installed it myself and chose plastic over copper. It's cheaper than copper (compression joints, anyway), and seems just as good. Better thermo properties too. I guess I could do the in-wall part in copper using bends and fit it all inside trunking. That might work. Fitting a towel radiator with pipes coming out of a solid wall seems like a very common thing to do so I'm just wondering what is "normal"!
It is normal bit posh having a towel rail but I can forgive that. Yeah they do rave about plastic. I agree. But in sight it will be what? Outside where its on view not plastic surely?
God its like watching paint dry coz I really am watching paint dry Oil paint I could be here for dayyyyys
"In- wall" What's is this "in-wall"? That makes no sense to me. IN the wall is already plastic is it not? Do you mean along the wall? Where peeps can see it? Or going into the wall? As in joining copper to the plastic? How is a girl ever to learn with all this lingo going on.
If there aren't any joints then a joint can't leak is my opinion. I've seen speed fits and compressions leak after a period of time, I know they shouldn't, but heh, why take the risk, even if it is minimal.
Hence the boxing and not cementing them in So I'm right yeah? Sort of I'm right sort of yeah ? Even a little bit yeah would be good
