Chimney Breast Removal
Discussion in 'Builders' Talk' started by blinding, Mar 25, 2005.
  1. blinding
    blinding New Member
    Hi
    As anyone got any good links to guides on removing/supporting an existing chimney breast located on a party wall of a semi-detached house? My house has 2 chimney breasts that join into 1 stack in the loft, I only want to remove 1 of the chimney breasts on both ground and first floors. (I would sooner use a lintel rather than brackets.)
  2. dirtydeeds
    dirtydeeds New Member
    why, whats wrong with the gallows brackets route
  3. gadget man
    gadget man Well-Known Member
    This subject has cropped up several times recently. This is not a job for the DIY'er...get the pro's in !!
  4. Jim
    Jim Guest
    You say you would rather use a lintel rather than brackets, the two actually go together, the lintel(s) sit on the gallows brackets.
  5. dirtydeeds
    gadget and jim, agreed
  6. blinding
    blinding New Member
    I have been advised that if gallow brackets are used I will need to get a party wall agreement, as it will prevent my neighbour removing his chimney and using gallow brackets to do so.
    Whereas if I use a lintel, the lintel will sit on the cavity wall and a partition wall which extends down to the foundations, this way I will not need a party wall agreement, as by using a lintel it will not affect my neighbour.
    The way I understood the lintel method it does not require gallow brackets, simply 1 lintel from wall to wall then two lintels at 90 degrees to that one, going from lintel to the chimney wall.
    Thanks for your comments, more are very appreciated.
  7. salem2000
    salem2000 New Member
    Any structural work on a party wall requires agreement, the work will also require inspection by the local Building Regulations Officer.
    I would suggest that you contact them first, their advice is free.
