Hi I am replacing my basin taps.i bought a pair of taps with 22mm tails and want to connect these to two 15mm original isolation valves by way of two flexible compression hoses. Have looked in the screwfix catalogue but not sure what to order. Any advice would be appreciated Jackie gee
All sorts of ways to tackle this, from using a standard 22mm to 3/4" flexible hose and then a reducer from 22mm to 15mm to suit your current valve, or even by buying flexible tails which already have valves on them and then reducing the size. Or by using these: http://www.screwfix.com/p/wras-hose-15mm-x-3-4in-x-500mm-x-10mm/65966 and using a short - 2" - length of 15mm pipe to join it to your existing valves. It's just like a watery 'mechano' set - find the bits that fit and stick 'em together
