I'm running most of my waste pipes in solvent weld I have 40 mm from shower then a reducer to 32 mm in solvent weld pipe as it hits the sink area . The sink waste is in 32 mm compression Question is I can't find a connector that will allow me to connect my 32mm compression from sink to connect to the rest of my 32mm solvent weld pipe . Is there such connector available?
Look at McAlpine Multifit connectors. https://www.google.co.uk/url?sa=t&r...2DPUZceFVWkpeg&bvm=bv.147448319,d.ZGg&cad=rja
Ah right didn't know that. I don't really need adaptor then . I could run the 32mm from sink into a 32mm straight compression joint then and carry on with the solvent weld ?
