Concealed toilet inlet pipe
Discussion in 'Plumbers' Talk' started by Stemoz, Aug 22, 2017.
  1. Stemoz
    Stemoz New Member
    hi,
    We have fitted the concealed tank to the vanity unit but I cannot find a 90 bend as we only have 30mm to play with. please help!!
  2. KIAB
    KIAB Well-Known Member
    Concealed tank to the vanity unit:confused:
    What size pipe are we talking about?
    Photo's:)
  3. DIYDave.
    DIYDave. Well-Known Member
    Are you talking about the flush pipe from cistern to toilet ? Maybe ?
    Your post is way to vague for any detailed advice. More info and some photos would help enormously :)
  4. Stemoz
    Stemoz New Member
    It's the threaded pipe that allows water into the system. 15mm I think
  5. Stemoz
    Stemoz New Member
    :)Apologies as I am no expert and your help is greatly appreciated
  6. terrymac
    terrymac Active Member
    do you mean there is not enough space to fit an elbow onto the 1/2 inch bsp thread of the inlet valve because the cabinet is too close ? is that your problem ?
  7. Stemoz
    Stemoz New Member
    Yes, that is the problem
  8. KIAB
  9. Stemoz
    Stemoz New Member
  10. DIYDave.
    Devil's Advocate likes this.
  11. terrymac
    don't think that will bend to a tight enough radius to fit in that small space kiab. a female elbow would . 1/2 inch bsp female to 15 mm compression. screwfix code 3231G. PTFE tape will be needed to seal between the threads.
  12. Stemoz
    Stemoz New Member
    They all seem too big to fit the gap. I need a 90 bend that goes straight down instead of having to much of a radius on it. Maybe a bent flexi hose connector if one exist So?
  13. KIAB
    I don't have a B&Q angled hose I link to here to measure,but it's preety compact.
  14. Stemoz
    Stemoz New Member
    Thanks but radius on this will be around 50-60mm
  15. terrymac
    the female elbow is the best bet .
  16. Stemoz
    Stemoz New Member
    Thanks. Looks bigger than 30mm but I could go and measure it
  17. Mike83
    Mike83 Active Member
    Is there another vanity to the left of the W.C vanity?
    If so it could be piped through that.
    WillyEckerslike and terrymac like this.
  18. Stemoz
    Stemoz New Member
    Unfortunately not
  19. terrymac
    the female elbow takes much less space than other fittings as
    the thread of valve goes into the female thread around 15 mm .
  20. DIYDave.
    IMG_3732.JPG I thought a had a bent tap connector in my plumbing box and yes I did
    As you can see from the pic, once it's seated on the threaded tail it is pretty much spot on 30mm
    Could maybe trim a bit of the threaded tail off to give a few more mm or pack some extra washers on inside of cistern to again shorten tail (assuming room inside for inlet valve)
