i need to take this down & wondered if my easiest option would be to support it then use an angle grinder to chop it off in pieces? Thanks
I need to take it flush with the brickwork as I'm installing a different canopy. If it is acting as a lintel surely if I'm leaving it intact apart from the protruding slab it should be ok?
Bit out of my knowledge, but it would lose strength by cutting it back. I'm sure one of the builders will be able to confirm if it's likely to be an issue or not
How far does the concrete canopy extend inward? looks like 3/4 brick length. If the concrete doesn't extend into the inner leaf of the house, then you will considerably weaken it by cutting it flush, it will be reinforced with steel rebar. The other option is to remove it completely and install a lintel, maybe a sing leaf catnic.
I would completely remove it and fit a concrete lintel in its place, I'm assuming your putting a porch up spot will be hidden.
No porch just a canopy, the concrete slab appears to go into the brickwork but will have a better look tomorrow.
From what I can see it goes in at least 2 bricks so surely lopping the overhang off cant cause any problems? Thanks
Wishful thinking... And the chances are you would get away with it. But the folks on here won't say "yeah - do it!" unless they know for sure it'll be ok. Sadly it doesn't look as tho' anyone on here has come across that kind of setup before. Any chance of a photo of the top of the canopy, where it fits into the brickwork? Anyways, until you know for certain, it'll chust have to be your call. Very likely you will be able to cut it nigh-on flush and your house won't fall down. But we'll all come round to do a 'Nelson'* if it does... * The Simpsons
All this chop it off bit by bit or even cut straight through it isn't going to work if you are putting that canopy up you posted, it will at best look shiit and at worst end up with concrete cancer where you have cut through the reinforcing steel and moisture creeps in causing rust which in turn explodes the concrete from the inside out. Fitting a new concrete lintel will still not look that good due to being on show,but at least it will be weather proof.
Ooooh - good point, Phil. I guess it could be painted a neutral colour to disguise the cut edge (matt black...), but - yes - the exposed rebar ends would need sealing effectively.
Remove similar concrete canopy over my back door a few years ago, ended up competely removing it & replacing with a single leaf cantic lintel, as the rebar was about 150mm in from the edge of the slab, so no use as a lintel to support above brickwork..
