Cooker Hood Extrator needs to go through the roof to vent
Discussion in 'Builders' Talk' started by davidrf, Dec 9, 2016.
  1. davidrf
    davidrf New Member
    Hi
    Just moved into a new (OLD COTTAGE) house that has an extension at the back. The kitchen is located here. Just had to fit a new extractor for the cooker and found the old extractor was not connected at all.
    So i am going to have to put ducting out through the ceiling and out through the roof (as this is the easiest option)
    Can anybody give me advice on how best to duct out through the roof.
    I have already opened the ceiling and the ducting can go through the roof space and out through the tiles but what is the best method to get the maximum extraction.
    Any advice on what actual products to purchase to do the job would be great.
    Thank you in advance for your advice
    David
  2. KIAB
    KIAB Super Member
    A ordinary cooker or a range, what width of hood, the better hoods are more powerful & use 150mm ducting.
    What the length of run you looking at for ducting.
  3. kiaora
    kiaora Guest
    Hi
    Often the the extractor is in fact a filter that recirculate the air through a filter and not actually extract.
    With extraction, especially vertical, condensation is the issue, the moisture inthe air will condense and trickle back
    Regards
    Peter
  4. KIAB
    KIAB Super Member
    Better through the wall.:)
  5. Joe95
    Joe95 Screwfix Select
    I agree. Core through the wall is also much easier to do than going through roof tiles.
    PVC flexible ducting increases noise as air resistance is increased, as opposed to using fixed plastic ducting. Condensation would also sit in the ribs of flexible ducting.
    David, does the extractor you purchased have a rear or top exit? As Kiaora said, extractors also come in a ductless option.
  6. KIAB
    KIAB Super Member
    Not a problem if top, can use round bend or round to flat retangular bend.
    Joe95 likes this.
  7. davidrf
    davidrf New Member
    Width of ducting is 150mm. hood is 90cm
    CDA EVP91SS 90cm Chimney Hood
    Ducting run is straight up about 1.5 metres no bends
    Kiab
    Someone recommend it being vented out using a KLOBER UNI LINE SLATE VENT (any ideas if this is preferred over a small flue?) Thank you all for your replies
  8. davidrf
    davidrf New Member
    CDA EVP91SS 90cm Chimney Hood top exit extractor and it has to go through the ceiling then through the roof as it cannot go out of the wall
  9. Joe95
    Yes, but rear exit would be much neater. I have a top exit here with a half height kitchen cupboard on top of the extractor, so it cannot be seen.
  10. KIAB
    KIAB Super Member
    You’ll need a ducting kit with a 150mm diameter.
  11. Joe95
    Alright, no need to shout :D
    davidrf likes this.
  12. KIAB
    KIAB Super Member
    Could you vent it through the eaves?
    [​IMG]
    Can then put slight fall on ducting, allowing any moisture to run to the outside.
    Joe95 likes this.
  13. Joe95
    You could still go out of the wall with the metal cover still meeting the ceiling, it would be easier to do and you would not notice it from the inside.
    As KIAB said, you can use a 90 bend and go straight out of the wall
    I have done it with this style of extractor.
    Are you sure you definitely want to go out of the roof?
  14. Joe95
  15. Joe95
    Didn't refresh the page so i didn't see this before posting:oops:, oops.
  16. davidrf
    davidrf New Member
    Hi Joe thanks for the reply. Tomorrow we are going to investigate taking it through the roof space but out through the wall there. Unfortunately it has to go up through the false ceiling as there are cupboards next to the extractor. But we know the roof space is one void as we have cut whole in the ceiling today. Thank you for your advice David
  17. davidrf
    davidrf New Member
    Kiab Thank you for your reply as mentioned in my post to Joe going to investigate if it can go through the wall. We never took into consideration condensation so more investigation needed tomorrow David
  18. Joe95
    Take assessment of the roof gradient, you would ideally need to know the fall/degree of the roof to choose the right roofing vent. Also take note of how the roof is laid, is it slate only, paper and tile etc. as this will be important for working out how to properly seal and insulate the new hole you open up.
    davidrf likes this.
  19. DIYDave.
    DIYDave. Screwfix Select
    Sounds like it's going to be a long run to vent outside do use solid pipe instead of flexi ribbed stuff
    Can also add a condensation drain to the vertical pipe up to roof. Generally available for 100, 125, 150 mm pipes and connect to 21mm overflow pipe and out through soffit
    Insulate the pipe as well with some type of foil, bubble wrap blanket to help minimise condensation forming
    Try to keep pipe run as short as possible and minimum bends. Depending on what tiles are on roof, a weathering slate will allow the pipe an exit whilst maintaining a seal
    davidrf likes this.
  20. davidrf
    davidrf New Member
    Hi Dave just measured from the extractor to the roof is around 1 metre to go through the slate roof so its not such a long run. Thank you for the advice on the overflow pipe will look into that as well
