Miss P will look some up for you. But in the mean time, these are good. http://www.screwfix.com/p/erbauer-3... Accessories&gclid=CKXg59b4g8cCFRQatAodCLALww
Suprisingly these seem quite good, not usually a fan of Erbauer,especially their power tools. A 5 piece Mexco set here: http://www.sitebox.ltd.uk/mexco-11-...paidproducts&gclid=CIH1htD5hMcCFSrpwgod8EsOdQ
Thanks K, looks like a very good price. Also looks similar to a set I saw in Selco this morning, 'ox' branded. Not as good a price as that though!
Covers every hole size you will usually need. Might find looking through Quidco for the Mexco set, might save a few more pennys.
Never had a problem with them, use a lot Mexco stuff, like diamond blades. http://www.mexco.co.uk/Products
In the MEXCO set they have a 117mm and a 127mm core. Is one for 4" and one for 5" holes? If so what are they only 10mm different? I have a 127mm and it is a pain in the rear to get a 5" duct hose through.
Duct hose is slightly larger diameter due to ribbing than 125mm rigid ducting. It's about 132mm overall diameter if my memory is correct.
